It is currently Sun Sep 14, 2025 11:58 pm
PostPosted: Sat May 18, 2024 9:42 pm
How do you hold the top and back plates steady when carving braces.
Do you use a special jig?
Do you use some sort of special mat to lay the top/back on?
Formerly know as Mandodiddle.
PostPosted: Sat May 18, 2024 9:55 pm
I have a little table a bit bigger than the top or back, with 3" legs. It gets the work a bit higher, allows for clamps, and I can drape it over the side of the bench to work at an angle. Old school, no vaccum, nothing fancy. Saw it in an old workbench book; it's what Somogyi was using at the time.
These users thanked the author Pat Foster for the post: Kbore (Mon May 20, 2024 1:08 am)
PostPosted: Sat May 18, 2024 9:58 pm
Non slip router mats, one under the radius dish, one in…
These users thanked the author meddlingfool for the post: Kbore (Mon May 20, 2024 1:09 am)
PostPosted: Sun May 19, 2024 6:39 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I show my setup here:
viewtopic.php?f=10101&t=55545&hilit=Total+vise
I’m very, very happy with it. I use workboards that are dished out for the applicable radius of the braces: 28’ for the top, 15’ for the back. These are mounted to a Total Vise mounting plate, and the mounting plate goes into the Crossover Mini, which goes into a base that is bolted to my workbench through dog holes. Solid as a rock, but capable of being positioned however I want. Not cheap, but if your back bothers you, this is a great way to work.
These users thanked the author doncaparker for the post (total 2): Kbore (Mon May 20, 2024 1:22 am) • bcombs510 (Sun May 19, 2024 6:58 am)
PostPosted: Sun May 19, 2024 8:37 am
http://www.kennedyguitars.com/holder-fo ... aping.html
I have holes drilled in the radius dish in proper places to put dowels for stops. I have a guitar shaped cork covered cardboard to put under the top.
Last edited by Terence Kennedy on Sun May 19, 2024 1:29 pm, edited 1 time in total.
These users thanked the author Terence Kennedy for the post (total 3): Kbore (Mon May 20, 2024 11:55 am) • rbuddy (Sun May 19, 2024 1:21 pm) • bcombs510 (Sun May 19, 2024 8:53 am)
PostPosted: Sun May 19, 2024 9:04 am
Non slip router mat, radius dish in go-bar deck and 2/3 go-bars.
PostPosted: Sun May 19, 2024 9:58 am
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
Left hand, palm down on the top (on a piece of carpet). Right hand holding chisel. I use a half inch chisel with a long handle, rounded corners on the tip, and bevel down. It is very sharp, takes light cuts, and doesn’t need much pressure. I turn the carpet as I cut rather than the top so that I’m not marring the top with any cutoff pieces. When I pick up the top to tap, that’s when I dump the shavings from the top and the carpet.
These users thanked the author bobgramann for the post (total 2): Kbore (Mon May 20, 2024 1:23 am) • rbuddy (Sun May 19, 2024 1:22 pm)
PostPosted: Sun May 19, 2024 12:46 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
Just what I use, that and some care.
Peter Havriluk
PostPosted: Sun May 19, 2024 1:11 pm
Radius dish and a couple of cam clamps.
I've learned, through experience, that it's best to avoid holding things with your hand when using a chisel. Basically, the shop rule is that both hands are behind the edge at all times, which means you'll use clamps most of the time, at least. Move the clamps when you need to; you're not in that much of a hurry....
These users thanked the author Alan Carruth for the post (total 2): Kbore (Mon May 20, 2024 1:26 am) • Robbie_McD (Sun May 19, 2024 8:14 pm)
PostPosted: Sun May 19, 2024 2:57 pm
Last Name: Gramann
State: VA
My hand is always behind the chisel point. I learned that long ago (and have a permanent crook in my finger to prove it). That’s why they call them “hand tools.”
These users thanked the author bobgramann for the post: Kbore (Mon May 20, 2024 1:26 am)
PostPosted: Sun May 19, 2024 5:19 pm
I use an adjustable solara, the top is easy. I use a rubberized mat for the back. Hands always behind the tip of the chisel.
PostPosted: Sun May 19, 2024 8:17 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
Like Alan said a couple of cam clamps in a radius dish - I use my sanding dish with a few layers of newspaper...works perfectly for me...
PostPosted: Sun May 19, 2024 8:53 pm
Pretty much what I do too.
PostPosted: Sun May 19, 2024 9:41 pm
Last Name: Colbert
City: Anacortes
This…
These users thanked the author Michaeldc for the post (total 3): James Orr (Tue May 28, 2024 10:05 pm) • Ken Nagy (Mon May 20, 2024 6:46 am) • bcombs510 (Sun May 19, 2024 9:57 pm)
PostPosted: Mon May 20, 2024 1:30 am
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
I put my radius dish on top of a 12” dia. lazy Susan and a non-slip mat on top of the dish. The lazy Susan provides clearance for the top to be clamped to the dish.
Measure Twice,
Karl Borum
PostPosted: Mon May 20, 2024 6:45 am
First name: Ken
Last Name: Nagy
City: Goodrich
Michaeldc wrote:
This…
Do you find that holding the plate around the entire edge makes a big difference over free plate tuning? I notice when glued up, plates that were tuned free, do need thinning around the edge; and even other places. On a carved instrument that is easy to do. I would be far easier to do on the inside with the bracing on a guitar. It usually isn't even that much material, but it does get more even.
Why be normal?
PostPosted: Mon May 20, 2024 1:38 pm
Last Name: Colbert
City: Anacortes
Ken Nagy wrote:
Michaeldc wrote:
This…
Yes, I can hear a change in pitch without having to use an analyzer. Free plate tuning never made sense to me - I couldn't hear any difference after I made a change.
Best,M
PostPosted: Mon May 20, 2024 7:30 pm
I usually graduate plates before gluing on the braces, and then use the Chladni method to 'tune' them. I find that I get better basses when I thin the plate toward the lower block, and better trebles when I thin the 'wings' of the lower bout. Chladni tuning, in my mind, is a method for getting the braces and the plate into some sort of balance, and the evidence of that is in the number and form of the modes. Well-formed modes tend to 'ring' longer when the held top is tapped, and produce a clearer sense of pitch, both of which are signs of low losses. Ultimately you can get much the same information either by tapping and holding, or with Chladni patterns. Tapping and holding takes less time, once you know how to to do it, but it takes more effort to get the same amount of information. I find it's also easier to teach the Chladni method, and easier to save the data.
These users thanked the author Alan Carruth for the post: Juergen (Sun May 26, 2024 10:09 pm)
PostPosted: Mon May 20, 2024 8:01 pm
Last Name: Kincheloe
I clamp pieces of wood to the edge of the bench so I have something to push up against. Best to have two stops, but after you get the rough shaping done it's usually quicker to have one that absorbs most of the cutting force, and left hand to prevent the top from rotating. I also use my left hand to help guide the blade, so it's out of the line of fire. Slipping and cutting the soundboard is the greater danger.
I use an old T-shirt as a pad underneath, and clear away the chips frequently.
PostPosted: Sun May 26, 2024 3:47 pm
Last Name: Cox
I lay the top on folded beach towels so I don't dent it up. I haven't had trouble with it shifting around so much as junk getting under it and leaving boo-boo's.
I shake the towels out regularly, and wash when needed.
PostPosted: Thu May 30, 2024 11:03 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
The plate (top or back) sits on a router pad inside a radius dish. I find it secure enough and CHEAP, I get to use my radius dishes for more than gluing braces.
Peter Havriluk
Users browsing this forum: No registered users and 85 guests
